Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
My motor story
Old Oct 17, 2006 | 09:55 PM
Willis_93ES's Avatar
Willis_93ES
Default My motor story
ok well as some of you already know.... but for you guys that dont....
I was crusing down the highway on a test drive with this stealth that i recentally bought for 400$ 1993 Mystic blue es 5speed. anyways i was going down the highway just at 80. and i was studying my gauges whenever i noticed my oil pressure dropping verry slowly. i'm not a big mechanic on these car types. but for the most part i love them. anyways... after my oil pressure dropped all the way down to nothing i killed the car and just coasted off the highway luckally to the gas station. so whenever i got there i checked the oil. it was really low. so i dashed inside and bought 3 quarts of oil and quickly put them in. only to find that the motor wont turn over at all. it just makes a clicking sound. i've had a couple of people tell me that it was "locked up" or "seised" and i want to get it fixed now. can i do it with a rebuild. or would i have to have a complete new engine block.
now it just sits on the side of my house. it pisses me off every time i look at it. but i need help guys. thanks
~Will
Old Oct 18, 2006 | 12:02 AM
91Stealth's Avatar
91Stealth
Default RE: My motor story
this is just a stupid question but i couldn't help asking... When it killed did you coast IN GEAR to the gas station or did you put it in Neutral???
Old Oct 18, 2006 | 12:03 AM
91Stealth's Avatar
91Stealth
cuz if you coasted in gear you not locked up...
Old Oct 18, 2006 | 01:24 AM
thestealth's Avatar
thestealth
Have you tried manually turning it over...just to be sure it's seized..?
Old Oct 18, 2006 | 03:01 PM
falcon66's Avatar
falcon66
You can repair a seized engine by rebuilding it. The bearings will have to be replaced and your crankshaft and camshafts may need to be machined or replaced depending on the damage. If the cylinder walls were damaged will have to be cleaned up by honing or boring over-sized. It may be cheaper to buy a long-block from autozone or somewhere else if available.
Old Oct 19, 2006 | 12:55 AM
Willis_93ES
ORIGINAL: 91Stealth
naw dude, i had it in netrual. and yeah i tried to "nascar" start it. me and a friend did it with emarrasment at a gas station....
Old Oct 19, 2006 | 12:24 PM
thestealth's Avatar
thestealth
ORIGINAL: thestealth
Depending upon how long you want to keep your car and if you plan on losing money for it when you sell, you may want to look into a factory shortblock from Mitsu.
Old Oct 19, 2006 | 12:54 PM
Willis_93ES
yeah thats the plan for now. i found a place that'll remachine everything for 2400$ here in ft worth.. god its going to be a long winter....
Old Oct 19, 2006 | 02:53 PM
thestealth's Avatar
thestealth
For a few hundred dollars more than that, you can have a brand new Mitsu shortblock...
Old Oct 20, 2006 | 03:40 AM
Willis_93ES
yeah but with the other deal. the cams get remachined and heads too. i believe. so its worth it. for another 2k i could land a TT motor
