Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
need help (emmissions)
Old Feb 27, 2007 | 02:58 PM
94stealthabq's Avatar
94stealthabq
Default need help (emmissions)
cant pass emmissions- runs to rich any suggestions?
Old Feb 27, 2007 | 05:46 PM
yevgenievich's Avatar
yevgenievich
Default RE: need help (emmissions)
catalytic converter might be burned out due to running rich
Old Feb 27, 2007 | 09:00 PM
TheMuffinOfEvil's Avatar
TheMuffinOfEvil
If you are failing by a slim margin, a set of high performance spark plugs could possably bump you over the edge into passing.
Old Feb 28, 2007 | 05:31 PM
falcon66's Avatar
falcon66
When I got my Stealth it ran rich. I found out that the spark plug wires were not fully plugged into the coil. All cylinders were getting burn, just not effectively. After cleaning out all the carbon deposits and fully plugging the wires in the car passed great. Checking/replacing spark plugs wires and cleaning the throttle body are some quick things to eliminate.
