Help with rear brakes
Old May 23, 2007 | 01:08 PM
ccrabtree1843's Avatar
ccrabtree1843
Default Help with rear brakes
Hi everyone, new to this forum and hoping I can get some help with a problem I'm having. I own a 1997 Stratus work car and my rear brake shoes continue to be ground down to metaland I'm at a loss as to what is causing the problem but it seems as if the shoes are not retracting. I have replaced on thepassenger and driver side the drums, shoes, springs and wheel cylinders and I have replaced the master cylinder, still the problem exists. I had the adjusters inspected by the local dealer's service shop to see if that was the problem and was told the adjusters were fine. I don't know what else tocheck out besides the vacuume booster.
Old May 23, 2007 | 04:19 PM
BloodRed's Avatar
BloodRed
Default RE: Help with rear brakes
Have you checked the e-brake?
Old May 23, 2007 | 05:13 PM
tacoboy's Avatar
tacoboy
Yes, check the e-brake and cable. I had mine seize up on me during travel - that was fun. I ended up having to disconnect it after realizing that I couldn't get the drum back on with it connected. It must have been pulling on it just enough to spread the shoes out.
Old May 24, 2007 | 01:42 PM
ccrabtree1843
E-brake checked. I disconnected the cable as well to see if it was the root cause and same thing happened, shoes got ground to metal within 2 weeks.Even prior to disconnecting I had rarely if ever used it. Could there be issues with the vacuume booster that would cause a problem like this. I have no issues with the front brake, they work fine.
Old May 24, 2007 | 02:50 PM
superstrat97's Avatar
superstrat97
have you done the rear hoses yet? because it is VERY common for the hoses to deteriorate on the inside and let pressure in when the brakes are applied but not allow the rear brakes to release, causing rapid wear
Old May 24, 2007 | 05:39 PM
ccrabtree1843
Thanks Superstrat, your the second person that has mentioned that and no I have not done that. Considering mine has about 177,000 miles it may be a good idea to do this.
