timing belt broke
Old Aug 19, 2007 | 08:04 PM
okley70's Avatar
okley70
Default timing belt broke
My timing belt broke on the road on the way home. What are the odds of having bent valve now because of that. its a 2.4L 4 cylinder automatic. And how the hell do I find out. I heard with this type of engine 9 out of 10 times you bend valves when the belt brakes.
Old Aug 19, 2007 | 09:39 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: timing belt broke
Best thing to do is install a new timing belt and before you put the covers back on start the engine. If it runs fine then put the covers on . If not running good, then the valves are bent.
Old Aug 19, 2007 | 10:11 PM
Dodge Tech's Avatar
Dodge Tech
or do a compression test b4 u start it up all the way.
