Transmission problem
Dealer quoted them at $102 ea. The two side ones might be little more ea. Dealer wanted
$210 total to change 1 Rt Frt Mount. I can get done for less, can probably do the Front and Rear myself. The side ones are in under other stuff. Depends how mechanical you feel.
If you want to PM me I can send you the link for the $82 mounts place, it's over East.
Mine's going in the shop again Monday for Steering Knocking and squeal at bottom of Steering Shaft, before the Warranty is gone. Does the noise with engine off, sitting still, rolling Steering Wheel left to right a little. Sounds like bad gear slop and a dry seal. Not really sure what is all in the end of this Steering Wheel Shaft, if it is directly into a rack or not.
