2000 stratus fuel filter question
Old Mar 29, 2009 | 01:38 PM
ronco05's Avatar
ronco05
Default 2000 stratus fuel filter question
I have 2000 stratus se. Is there a way to replace the fuel filter without dropping the gas tank? Thanks.
Old Mar 29, 2009 | 02:44 PM
pearl01stratcpe's Avatar
pearl01stratcpe
Have you popped up the bottom of the rear seat?
Old Jul 9, 2011 | 05:08 PM
pixelpadre's Avatar
pixelpadre
Smile Clogged Filter?
Hello. Hate to be a pest. But my questions might help someone else later.
I removed the filter, not much of a job. Jacked car up about 15" and dropped driver side gas tank band and partially loosened the passenger side strap. Driver side strap has to be completely removed to free the filter.
Ok gas filter has three hoses. Two go to the pump and third goes not sure where. So that is my question.
If I blow on either of the hoses that attach to the pump I find one blow freely to the mysterious third nipple on filter. Blowing on the second hose that goes to the pump meets significant resistance. I tried googling the operation of the fuel filter but all I came up with is that this 2000 stratus does not have a return line like many fuel injected systems.
So can you tell me if one is supposed to blow freely while the other doesnt? And a brief explanation of the operation of the filter might be enlightening to me and others.
Thanks
Old Jul 10, 2011 | 04:37 PM
pixelpadre's Avatar
pixelpadre
New fuel filter still didnt work. Not getting gas. Last thing to check is the pump/regulator.
Old Jul 10, 2011 | 04:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
Did you check the fuse's for the fuel pump and asd relay? You will need a 12 volt test light to check the fuse's.
Old Jul 11, 2011 | 10:08 AM
pixelpadre's Avatar
pixelpadre
Yes i have checked all the basics.
Fuel line is disconnected on both ends and I can not blow compressed air from either direction.
Old Jul 12, 2011 | 12:25 AM
master tech
Then something is clogging the line up.
Old Jul 25, 2011 | 05:07 PM
pixelpadre's Avatar
pixelpadre
Default bad fuel pump
Turns out that the fuel line has a check valve by the rail. Line was clear when I pushed on the check valve.
After changing dist, crank sensor, throtle sensor, fuel filter, it turns out it was the pump, even though it was still running.
Upon inspection after removing pump from tank, I saw charred wires with plastic melted off and the 4 pin harness half melted away. I will attached photo of this W&&** pump that I removed.
Attached Thumbnails 2000 stratus fuel filter question-2011-07-13-12.23.19.jpg
