Transmission pops when downshifting
Old Nov 5, 2010 | 02:43 PM
tbamaker's Avatar
tbamaker
Default Transmission pops when downshifting
Hey everyone, I need help identifying a problem with my gf's 2002 Stratus. Her car is the DOHC 2.4L Auto, 4dr. About a week ago, she informed me that sometimes when it was cold, early in the morning she would shift it into reverse or drive and it wouldnt engage the gears until it warmed up. So after talking to a mechanic friend of mine he said the filter may be old and clogged so the fluid doesnt reach the gears until it warms up. Checked her fluid and added some to it but then it started a new problem. Now, when you are slowing down it does a semi loud pop, and you can fill this in the car, but it only does it when downshifting back into first gear. It doesnt do anything while accelerating, drives perfectly normal. And when you are decelerating and you shift the gears manually, it also does not do it then either, just when the automatic transmission downshifts by itself first gear pops. I dont want to continue driving it this way and mess it up beyond repair, hopefully someone here can help me out with this.
Old Nov 7, 2010 | 01:01 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Here is a TSB that maybe the problem your GF maybe be having.
SUBJECT:
Transaxle Slips In Reverse Or First Gear
OVERVIEW:
This bulletin involves replacing the low/reverse accumulator cover and
O-ring during transmission repair.
MODELS:
2002 (JR) Sebring Sedan/Sebring Convertible/Stratus Sedan
2002 (PL) Neon
2002 (PT) PT Cruiser
2002 (RS) Town & Country/Voyager/Caravan
NOTE: THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH AN AUTOMATIC
TRANSAXLE WITH BUILD CODE DATES OF 1342 (MAY 14, 2002) THROUGH
AND INCLUDING 1502 (MAY 30, 2002). REFER TO THE APPROPRIATE
SERVICE MANUAL OR MDS2 SERVICE INFORMATION FOR THE TRANSAXLE
LABEL LOCATION AND CODE INFORMATION.
SYMPTOM/CONDITION:
Some vehicles may have a transaxle that will not move or slips in Reverse or First gear.
DISCUSSION:
Vehicles equipped with automatic transaxles built in the range specified that exhibit
the condition(s) listed above may also have Diagnostic Trouble Code(s) (DTC)
P0736, Gear Ratio Error In Reverse, or P0731, Gear Ratio Error In 1st set. All
vehicles that fall in this category must have the Low/Reverse Accumulator
Cover and O-Ring replaced during transmission repair.
PARTS REQUIRED:
Qty. Part No. Description
1 04431617 Cover, Low/Reverse Accumulator
1 06501549 O-Ring, Low/Reverse Accumulator
