stratus sedan transmission trouble
I have a 2002 DODGE STRATUS 2.4 dohc sedan.The other day my daughter was driving to school and it just lost all power acts as though it is in neutral.I pulled the codes and I have p0442(emission leak small)p 0455(emission leak large)p 0720 (output speed sensor malfunction)P 0715 (turbine speed sensor malfunction)p 0846(trans fluid pressure sensor/switch b ckt range perf.)and p 0700(transmission control system malfunction).I changed the input and output speed sensors.I also changed the shift solenoid.None of these fixed the problem my next guess is tcm.is there any way to check the tcm to see if it is good.Or does any one have any Ideas I feel as though I am beating my head against the wall.The car has 188,000 mi.and still runs like a champ.I dont think a plugged tranny filter could cause these problems.could they?the car has the original battery I was told they cause issues like this.but my battery light never came on.I just need help I like to fix things myself.I dont have 1500 to 2000 for a shop bill if any one could help I would be thankful.
castlenut.... the car will start right up no problem.when I go to put it in gear it even sounds like its going into gear.I have had tourque converters go out on fords that seem just like this....................................Mastertech yes p 0700 trans control malfunction came back.once I changed parts I erased the codes .
