Creeking noise when turning
Old Dec 27, 2010 | 06:53 PM
needahemi's Avatar
needahemi
Default Creeking noise when turning
I have a 2002 Dodge Stratus Sedan, 2.7L, with about 90K miles. Recently noticed a very loud noise when turning left or right. Sounds like opening a door with rusty hinges.
Oddly enough the noise doesn't occur when the car is first started. Also if I turn the wheels all the way to the left and then right , the noise reduces significantly. The noise seems to be coming from the LH (driver's) side.. like at my feet when I am behind the wheel.
I am starting to believe that the noise is due to the power steering pump failing and cavitating. I don't notice any issues with the steering other than the noise. I'm hoping its not a steering rack which is much more expensive and difficult to replace.
Does anyone out there have similar experience with this issue? Thanks!
Old Dec 27, 2010 | 11:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
The creeking sound maybe the lower ball joints or the inner tie rod ball of the rack n pinion.
Old Dec 28, 2010 | 04:19 PM
needahemi's Avatar
needahemi
Thanks... I got under the car today and had my daughter turn the wheels back and forth. Appears the culprit is a bad lower ball joint. Boot is torn and noise seems to be coming from the joint.
