Brake light/dome light/radio issues.
Hello, my girlfriend has a 2000 stratus 4cyl 2.0 . Whenever she would hit the brakes the radio would go off and stay off until the next time it was started up. Dome light does not work at all and i've noticed the brake lights do not work at all. So my research said brake light switch so i took it off. When i moved her car to take my truck to advance auto for the new part, the radio worked just fine while applying the brakes multiple times. However i did not notice if the lights worked. I replaced the brake light switch and nothing works still. Ive checked all fuses and lights bulbs all is fine. I am lost, any help would be awesome.
No work has been done on it this past year.She bought the car off her best friend so i will make a call and find out more info.Problem started roughly around Thanksgiving. I do appreciate your quick responses.
Other than that, try unplugging the stop switch and see what happens, if everything works (except brake lights) then check for corrosion and then spray some electrical contact cleaner in plug end and switch end and plug/unplug a few times to clean any varnishing that MAY have occured, then leave plugged in and see what happenes...if the problem still persists then you have some diagnosing to do in the brake light circuit...
I can try to help you by explaining things to check for after you've tried everything I listed thus far, but I may not be very useful because I have a hard time explaining electrical on a beginners level...no offense, but I have been around it my entire life and based 5 years of college in that specific field so it just comes natural to me and makes perfect sense in my head, but to put it into words can be difficult for me.
Anyway, try what has been suggested so far and go from there, if no luck, come back here and explain to the best of your ability what is and is not happening and hopefully I or someone else will be able to help.
Trending Topics
Lol... No offense taken, I understand how u feel. I'm an electrician myself, just clueless when it comes to cars. Too many wires, and too many you can't see. I have checked all fuses, and replaced all 3 brake lights. Taillights have been fine. Car sat for a week at my shop,then radio started going out when I hit brakes. Didn't know til yesterday that my brake lights didn't work. Been going on for about 3 months, was just living with radio not working. I unplugged the stoplight switch, and nothing happened. Not sure where to go next. I may need to start checking all wires for shorts, possibly pull radioi and chek it out.
Appreciate any help with this.
You can go about checking for shorts just fine, but I have found it a waste of time to start ohming out the wiring in a car. Cuz chances are if there is an issue with current due to high resistance, it's hard to find this way cuz of stranded wires. Just like hooking a dryer up with phone wire...it'll ohm out and show continuity just fine with your trusty Fluke, but will NEVER carry the current needed to start up the dryer...same thing applys here, usually a couple strands will still be holding on for dear life, and unless there is a lot of corrsion in the break, those strands will read (near) 0 ohms. Just get the schematic and check for voltages in places, and remember you are dealing with computers so many of your voltages may be only 5 volts or even 2V...not 12 volts like you MIGHT think cuz that is what the battery is. Basically if you see ANY significant voltage at your test points, it is probably working just as it should.
Let me know what you may find out and we'll go from there.
