2004 dodge stratus blower motor resistor
so I am basically new to all of this and I have my car torn apart at the moment. I bought the blower motor resistor from a website and it says this is the correct part can anyone walk me through how to actually get this changed and functioning. I would greatly appreciate the help I don't want to run to the issue of a non defrosted window and not be able to fix it. I cannot find diagram anywhere on the internet or directions in my owners manual.
thanks in advance for any help and if you would like to email me you can at jasonbran16@gmail.com.
ps pictures of the a great help.
on
Welcome to DF
REMOVAL
WARNING: On vehicles equipped with airbags, disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in accidental airbag deployment and possible personal injury or death.
WARNING: The blower motor resistor may get very hot during normal operation. If the blower motor was turned on prior to servicing the blower motor resistor, wait five minutes to allow the resistor to cool before performing diagnosis or service. Failure to take this precaution can result in personal injury.
Disconnect and isolate the negative battery cable.
Remove the silencer panel from right side of the instrument panel.
Disconnect the wire harness connector from the blower motor resistor located on the bottom of the HVAC housing (Blower Motor Resistor).
Remove the two screws that secure the blower motor resistor to the HVAC housing and remove the resistor.
REMOVAL
