96 Stratus A/T pan bolt torque specs
Old Feb 13, 2011 | 04:24 PM
Kradisco's Avatar
Kradisco
Smile 96 Stratus A/T pan bolt torque specs
Need to replace A/T pan (due to hole from rebar) but can't find bolt torque specs on-line. Chilton Manual @ local Lib. is checked out and won't be available for 2-wks. . . would like to finish this today. . .1996 Stratus 2.4 SOHC (my guess is 30-40 in lbs, but would rather NOT guess)
Old Feb 13, 2011 | 05:17 PM
dolittle's Avatar
dolittle
Wish I could help I have a 2000 Stratus and just checked my Chilton manual and it doesn't tell what torque for the trans pan. I think your guess is good. Just check for leaks when your done. I'm sure you already knew that
Old Feb 13, 2011 | 10:41 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
41TE TORQUE SPECIFICATIONS
DESCRIPTION TORQUE
Cooler Line Fittings 12 N·m (105 in. lbs.)
Differential Cover 19 N·m (165 in. lbs.)
Differential Ring Gear 95 N·m (70 ft. lbs.)
Differential Bearing Ret. 28 N·m (21 ft. lbs.)
Driveplate To Crank. Bolts 95 N·m (70 ft. lbs.)
Driveplate To Torque Conv. 75 N·m (55 ft. lbs.)
Eight Way Solenoid Conn. 4 N·m (35 in. lbs.)
Extension Housing 28 N·m (21 ft. lbs.)
Input Speed Sensor 27 N·m (20 ft. lbs.)
L/R Clutch Retainer 5 N·m (45 in. lbs.)
Oil Pan To Trans. Case 19 N·m (165 in. lbs.)
Output Gear Bolt 271 N·m (200 ft. lbs.)
Output Gear Stirrup Ret. 23 N·m (17 ft. lbs.)
Output Speed Sensor 27 N·m (20 ft. lbs.)
Pressure Taps 5 N·m (45 in. lbs.)
Pump To Case Bolts 27 N·m (20 ft. lbs.)
Reaction Shaft Bolts 27 N·m (20 ft. lbs.)
Rear End Cover 20 N·m (125 in. lbs.)
Sixty-Way Connector 4 N·m (35 in. lbs.)
Solenoid Assembly To Case 12 N·m (110 in. lbs.)
Transmission Range Sensor 5 N·m (45 in. lbs.)
Transfer Gear Nut 271 N·m (200 ft. lbs.)
Transfer Plate To Case 12 N·m (105 in. lbs.)
Valve Body To Case Bolts 12 N·m (105 in. lbs.)
Valve Body Bolts 5 N·m (45 in. lbs.)
Vent Assembly 12 N·m (105 in. lbs.)
Old Feb 14, 2011 | 08:06 PM
Kradisco's Avatar
Kradisco
THANKS Master Tech ~ Also threw in a new filter & gasket. . . which said to tighten to 80 in lbs and then 120 in lbs. ~ that seems to be working fine with no leaks ~ new gasket does NOT require sealer ~ we'll see how that works ~ can always snug-up to 165 in lbs if a drip should appear.
