2002 dodge stratus noise
Old Feb 22, 2011 | 02:29 PM
Plasma's Avatar
Plasma
Default 2002 dodge stratus noise
i have a 2002 dodge stratus, and i just got it. i am noticing it pulls to the right front and when i turn to the right slightly it makes a odd thumping flapping noise, it sounds like wheel bearing. i checked the tie rod ends and visually looked at it all under there cant really see anything going on. its only happens when i'm slightly turning right to. i will try to get vid or sound of it but its a thump or like something getting bound etc..
i am thinking wheel bearing or tie rod end but i'm not sure...
any suggestions?
Old Feb 22, 2011 | 11:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I would go with the wheel bearings first and i would do both sides at the same time.
Old Feb 23, 2011 | 06:48 AM
22DODGE22's Avatar
22DODGE22
My thoughts are you need someone with mechanical skills to check this problem imediately. You might have a ball joint going bad. Don't risk your life and the life of others guessing when it comes to steering/suspension or brake issues. It's not worth the risk of miss diagnosis.
Old Feb 23, 2011 | 10:54 AM
Plasma's Avatar
Plasma
i agree, just trying to get an idea before i go to mechanic to see what is what. trying to figure out price etc.. what might be wrong. etc so i at least ain't totally in the dark.
any ideas on parts labor for these parts?
Old Feb 23, 2011 | 09:01 PM
22DODGE22's Avatar
22DODGE22
Well, if you can use a computer, you can look up parts cost like www.autozone.com or www.napaonline.com or www.advanceautoparts.com
Labor varies greatly on shop rates, competence of mechanic and likeability of the customer.
