New transmission problems..help please
Old Mar 17, 2011 | 08:29 PM
lectricheart's Avatar
lectricheart
Default New transmission problems..help please
Found out what my last problem was. When U-Pick-It knocked the hole in the trans oil pan, they went clear through to the valve body and took a chunk out of it. Wasn't noticable with the gasket plate on. Now I have a new problem. When I go into Drive, I get a hard clunk, and it defaults to 2nd gear. It won't downshift to 1st or upshift to third. I get a check engine light after a few tries. The fault codes are PO700-PO731-PO732. trans control unit (MIL requested)- 1st gear ratio incorrect-2nd gear ratio incorrect. Can anyone give me a clue as to what causes those faults, and what I can do to fix it??please..
Old Mar 17, 2011 | 08:47 PM
22DODGE22's Avatar
22DODGE22
Best would be to get another trans. Did you change valve bodies?
Old Mar 17, 2011 | 09:17 PM
lectricheart
yes,I changed the valve bodies out. And it shifted fine for a while. Still stuck on the TCM. any way to test them without takeing them to the shop? I live 44 miles from civilization..lol
Old Mar 17, 2011 | 09:22 PM
22DODGE22's Avatar
22DODGE22
You properly installed the 2 accumulators and springs that fell out when the valve body cameout?
You need a real scanner to accuratly assess what's going on with the trans.
Old Mar 17, 2011 | 09:39 PM
lectricheart
Very carefully reinstalled the accumulators and springs. What would you call a real scanner? Is that something you can purchase at AutoZone? I have a hand held scanner that reads the trouble codes.
Old Mar 17, 2011 | 09:54 PM
22DODGE22's Avatar
22DODGE22
Autozone tinker toy is totally useless on trans stuff. I'd own a quality professional scanner that one would have in a real repair shop. trying to fix anything on today's cars without a scanner... well might as well try building a house without tape measure.
