I keep getting different answers. Please help.
Old Mar 30, 2011 | 12:40 AM
silno03's Avatar
silno03
Default I keep getting different answers. Please help.
Can someone please tell me where the CRANKSHAFT POSITION SENSOR is located on a 2000 Dodge Stratus 2.4L? I've done a search and keep getting different answers like it's in front of the engine above the starter or above the oil filter or behind the harmonic balancer. I'm confused. Please help.
Old Mar 30, 2011 | 12:57 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
This is out of the dodge service manual for 2000 2.4L engine.
CRANKSHAFT POSITION SENSOR - 2.0/2.4 L
The crankshaft position sensor mounts to the engine block behind the generator, just above the oil filter Crankshaft Position Sensor - 2.0/2.4L
REMOVAL
Remove the negative battery cable.
Disconnect electrical connector from crankshaft position sensor.
Remove sensor mounting screw. Remove sensor.
INSTALLATION
Install sensor and tighten the screw.
Connect electrical connector to crankshaft position sensor.
Install the negative battery cable.
Old Mar 30, 2011 | 02:06 AM
silno03's Avatar
silno03
When you say behind the Generator, does the Generator have to come out? Is all of this done underneath the engine or can I do this from the top? Any pictures or a more detailed instructions would be appreciated.
Also did a search on Ask.com and it stated that it was located in back of the engine by the firewall. Now I'm really confused.
Old Mar 30, 2011 | 02:13 AM
toomanycars's Avatar
toomanycars
its very ez to get out .. one bolt 10 mm on the back of the block .. its alittle plug .. the wires should be rapped in heat resistant material ... hope that helps ... ez to get to from under the car..
Old Mar 31, 2011 | 04:04 PM
silno03's Avatar
silno03
Finally, a correct answer. Thank you (toomanycars) for the correct answer. I nominate you for Tech of the week. Thanks.
