00 Stratus p0340 p0725 codes
Old Apr 17, 2011 | 02:52 PM
thom1952's Avatar
thom1952
Default 00 Stratus p0340 p0725 codes
00 Stratus 2.4 dohc died while driving. It was like I turned the key off. Turns wont fire cel light was on codes were P0340&p0725. Replaced cam & crank position sensors no change. Also bartery now dead but hasnt been run in a month. need to fix to find work
Old Apr 18, 2011 | 11:53 PM
master tech's Avatar
master tech
Site Moderator & Tech
charge the battery and remove the cam sensor. With a drop light look at the can sensor pickup plate. Have someone try to start the car.Does the plate rotate? If it doesn't, the timing belt has broken.
Old Apr 19, 2011 | 12:05 PM
thom1952's Avatar
thom1952
Yes it was timing belt thanx
