2000 Crankshaft Sprocket?
Old Apr 25, 2011 | 07:28 PM
Formerly's Avatar
Formerly
Default 2000 Crankshaft Sprocket?
I'm looking for a replacement sprocket, at the moment they seem impossible to find. I'm finding almost anything but it. Does anyone happen to know where to find them or anything?
For reference, they should look like this ... Minus the broken pieces.
http://img855.imageshack.us/img855/6305/0425111708.jpg
A kind of barrier on one side, long trenches for the timing belt, and many screws on the flat side.
Old Apr 25, 2011 | 08:47 PM
ledsd's Avatar
ledsd
google year make model
and you should find what you need
thats what i do
junk yard too
Old Apr 25, 2011 | 09:14 PM
Formerly's Avatar
Formerly
I used google thoroughly and found everything but what I needed, as I stated in the original post. I even found a better replacement engine, at that. What I am finding most common are these two
http://www.autopartswarehouse.com/de...e&apwid61J48Hf
Crankshaft pulley
http://www.partsgeek.com/gbproducts/...ek+Google+Base
Timing sprocket
I'm not sure if a local store should carry what I need or where I would go about finding this piece. I'm not surprised it's being this difficult to find because it should not break considering the special tool used to safely pull it out. I'm not too sure about the junkyard either, considering if I had to pull the part ... I would have to remove almost the entire left side of the engine.
Also ... I'm not sure if I'm even looking correctly. If this part may have another name or if there's a different way to look for it. Under the manual it confirmed to be called a "crankshaft sprocket" but ... If so, why can't I find it?
Apologies for any frustrations. This has been a problem car since the start.
Old Apr 26, 2011 | 12:14 AM
master tech's Avatar
master tech
Site Moderator & Tech
The Mopar part number is 04648939AA for the sprocket, there also a sprocket key you may need too. Mopar number for the key is 6035473. Call your local dealer and order it.
Old Apr 26, 2011 | 12:38 AM
Formerly's Avatar
Formerly
Thank you so much! I have the key just that the sprocket was damaged in removal. Looks like I have some calling to do.
Can't wait to see her running again.
Old Apr 27, 2011 | 01:53 PM
castlenut's Avatar
castlenut
Never mind good LUCK!!
Old Apr 27, 2011 | 11:16 PM
master tech
castlenut
What was on your mind? Always open for anyone's throughts.
