keyless transmitter
Old Jul 8, 2005 | 09:33 PM
robnva's Avatar
robnva
Default keyless transmitter
does anyone now how to program an additional keyless transmitter on a 2004 dodge stratus r/t?
Old Jul 8, 2005 | 10:07 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: keyless transmitter
hey, i replied to your PM. in addition, i think that itll run you about 50-70 bills.
Old Jul 8, 2005 | 10:19 PM
alpine25's Avatar
alpine25
Dealership's OBD2
If thats not what he said
If you know someone that works there, you can usually get ity for free
Old Jul 8, 2005 | 10:30 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
its just a little handheld thing...it doesnt cost the dealership a DIME to do it, and thats the CRAP of it all,...[:@]
Old Jul 8, 2005 | 10:42 PM
alpine25's Avatar
alpine25
Dealerships will do anything for $$$, thats all they care about
(Dad works at one)
I detailed there for a while, they would only give me 20 out of 110 for a full detail.
I work at a private shop now and get HALF of whatever they charge.
Old Jul 8, 2005 | 10:53 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i worked for a school run detail shop in college...we spent all of our time dicking around or detailing the chancellors caddys...
on a side note, alpine, you should get some pics of your car all shined up and put them in the gallery!
rob, maybe just try calling a few different dealerships and see if they will out price each other.
Old Jul 8, 2005 | 11:01 PM
alpine25's Avatar
alpine25
So true about the dicking around part.......
We had a golf cart to mess with at the dealership.....
cadilac emblems, cb radio, stereo, it had it all lol.
The shop im working at now gets a lot more work that the dealership,
they tint as well, so thats where we get a lot of the traffic.
As for the pics, my camera's not the best, but i will see what I can do
Old Jul 14, 2005 | 01:31 AM
B_52's Avatar
B_52
Are you talking the coupe?
Is the 04 that different than the 02? (If so, That bites!)
The 02 is owner programable!
V
Old Jul 14, 2005 | 11:40 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
how is it programmable? i have an 02...and i am unaware...
Old Jul 15, 2005 | 04:25 AM
B_52's Avatar
B_52
You can reference the procedure in the 2002 Factory Service Manual Volume 1, Section 8P-9
The 2002 R/T Coupe can learn up to 4 transmitters.
You cannot “ADD” a transmitter one at a time. You must register ALL your transmitter, new and old at the same time.
THE CHRYSLER VERSION:
1.) Check the doors lock normally when the key is used
2.) Insert the ignition key (NOTE: to prevent damage, always turn the ignition switch to "LOCK” (OFF) position.
3.) Ground terminal 1 of the data link connector (image shows this as a two row, 16 pin connector located directly under the steering column. The wide side is pins1-8, with 1 being to the right.)
(Wish I knew how to include the image here, but I don’t sorry.)
4.) Press the hazard switch six times within 10 seconds. (Note: at this time the code registration monitor request is output [all doors locked and unlocked] and becomes registration mode.) (NOTE: The hazard warning light switch is turned on and off alternately whenever pushed.)
5.) Press the transmitter switch, and then press it two times within 10 seconds of the first press. This will register the code.
6.) When the registration is complete, the code registration monitor request is output(all doors locked and unlocked).
7.) If you are using two or more transmitters, or have added a second transmitter, the same registration procedure should be carried out within one minute after registering the first transmitter. After the second registration is completed, the code registration monitor request is output(all doors locked and unlocked).
8.) Registration mode will be canceled under any of the following conditions
8a.) when the secret code of the transmitter has been registered
8b.) when one minute has been passed after registration mode.
8c.) When the ground wire to pin one is removed
8d) When the key is removed from the ignition.
9.) After registration is completed, carry out the following work, and then check that the keyless entry system operates normally.
9a.) Remove the ignition key
9b.) Close all the doors
THE SIMPLIFIED VERSION?
I think the simplified method is more like this, but don’t hold me to it until someone tries it, cause I haven’t!)
1.) Insert key in ignition, set to “Off” or “Lock”
2.) Ground pin 1 on the Datalink connection
3.)press the hazard switch 6 times within 10 seconds
4.) press the transmitter button 3 times within 10 seconds
(System will respond by locking and unlocking doors as acknowledgment)
Here is where it gets muddled for me, as I don’t think you need to repeat step 3, but instead simply do step 4… I may be interpreting it wrong.
5.) Repeat step 4 for all additional transmitters, within 1 minute of last attempt.
6.) When done, simply remove ground from datalink connector
Peace
Vince
