Add on Trip Computer
Subscribe
Jun 11, 2011 | 06:27 AM
I have a 2005 Dodge Stratus SXT 2.7 V6. Is it possible to add the trip computer to my car? Would it be just plug and play or is that not even an option. Thanks in advance!
Reply 0
Jun 12, 2011 | 11:21 PM
Your car should already have a trip meter. Push the button, you should see trip A and trip B.
Reply 0
Jun 13, 2011 | 12:42 AM
I'm talking about adding the computer to the dash that goes between the two vents above the ac controls. I think out comes standard in the higher end stratus. It has has temp, gas mileage, trip meter, etc...
Reply 0
Jun 13, 2011 | 02:34 PM
Is there a bezel that can be removed to install a traveler module? First you would need to find out if there is a wire connector for the module. If you have the connector, there are four number for the module, four numbers for the bezel cover for the module, and if you need to cut a in the instrument panel, there is 12 part numbers for a new instrument bezel.
Reply 0
Subscribe
