98 Stratus odd Fuel delivery problem
Old Jun 13, 2011 | 07:19 PM
Lilmikep's Avatar
Lilmikep
Default 98 Stratus odd Fuel delivery problem
I am a mechanic at a local shop and want to make sure I am not missing something that Dodge guys know about. 98 Stratus with a 2.5L towed into shop today. No fuel pressure at rail. Checked power and grounds at fuel pump, all good. Replace fuel pump and filter, still no pressure. I can hear pump working. After getting frustrated, I looked for physical damage to line, None found. Here is where it gets interesting. I disconnected fuel line at passenger side undercarriage. I have fuel pressure ther. About 3 ft up at the rail, ZERO. Any known defects with the portion of line from under car to rail? Thanks for any help
Old Jun 13, 2011 | 10:58 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
What is the fuel pressure and flow going into the fuel rail? The fuel lines haven't been a problem. Remove the line from the fuel rail and at the fuel filter. Blow air thru the line.
Old Jun 14, 2011 | 06:32 AM
Lilmikep's Avatar
Lilmikep
I am pumping 56psi at the lower connection and zero at the rail. And, I can't blow air thru line, tried but no go. Probably going to replace line today.
Old Jun 14, 2011 | 12:23 PM
ratsttam's Avatar
ratsttam
Yep. If you can't get air through it, fuel sure isn't going to make it. Something may have kicked up and crimped the line?
Old Jul 1, 2011 | 06:11 PM
pixelpadre's Avatar
pixelpadre
Default Pinout for harness
I have been going nuts lately. Car died driving down the road. Same thing happened 4 years ago and it was the distributor. So I put in new distributor, but no gas is getting to fuel rail. I swapped out fuel pump relay with a/c relay and that made no difference. I checked all fuses in the car and none were blown. Pump makes no noise when ignition is on. I pulled the harness apart under the back seat and found 7 pins. I dont know which two power the pump. I hate to remove the tank just to find out that the pump is not getting power. I have the dodge shop manual but that information is not anywhere in the manual.
I read that there is an automatic shutoff switch in the trunk somewhere. Is it possible that it has rusted or failed? I have no idea where it is located?
