T-350 Transmission Speed sensor
Was wondering if anyone would know what the voltage would read on the harness of the Speed sensor on a T-350 Transmission?
The vehicle type is 1996 Dodge Stratus 2.4L 5 Speed. I have had the issue for some time now and it is beginning to give me Idle issues i believe.
You should have an 8 volt supply and 8 volt sensor signal.
VEHICLE SPEED SENSOR (MTX ONLY) CAV CIRCUIT FUNCTION
1 K7 18OR 8 VOLT SUPPLY
2 K4 18BK/LB SENSOR GROUND
3 G7 18WT/OR VEHICLE SPEED SENSOR SIGNAL
