Interferance or not?
Old Jul 10, 2011 | 04:05 PM
divelblissn's Avatar
divelblissn
Default Interferance or not?
I need to know if my 2.4L DOHC stratus is interference or not. pretty sure timing belt teeth are messed up and making it not move. Really dont want to scrap this car.
Old Jul 10, 2011 | 04:15 PM
master tech's Avatar
master tech
Site Moderator & Tech
DESCRIPTION
The 2.4 Liter (148 cu. in.) in-line four cylinder engine is a double over head camshaft with hydraulic lifters and four valve per cylinder design (2.4 Liter Engine). The engine is free-wheeling; meaning it has provisions for piston-to-valve clearance. However valve-to-valve interference can occur, if camshafts are rotated independently.
The cylinders are numbered from front of the engine to the rear. The firing order is 1–3–4–2.
The engine identification number is located on the rear of the cylinder block (Engine Identification).
Old Apr 27, 2012 | 04:28 PM
Fuzzy_NM's Avatar
Fuzzy_NM
I realize there are no gaurantees here! However, what are the chances of valve to valve interference with a broken belt at 80 mph?
~Fuzzy
Old Apr 29, 2012 | 06:13 PM
castlenut's Avatar
castlenut
My girlfriend broke hers at 50 miles. I replaced it started rite up...
Old Apr 30, 2012 | 12:20 PM
ratsttam's Avatar
ratsttam
~Fuzzy
With a non-interference engine, it won't matter if you snap that timing belt at 5mph or 180mph. Nothing to hit because they NEVER occupy the same space. If they do hit, than you were dealing with a much worse issue than a bad timing belt to begin with.
With an interference, one single rotation is all it takes when the valves are down and the pistons are up, even at idle, not good at all.
