o2 sensor not communicating with computer
Old Aug 2, 2011 | 05:29 PM
speedo28's Avatar
speedo28
Default o2 sensor not communicating with computer
Hey can anyone help me out?Im having a problem with my o4 stratus rt 3.0 my service engine light is on and the o2 sensor1 bank 1 sensor and running running too lean codes were present I cleared the computer drove it above 60mph for few miles and it came on I did that 3 times then purchased a new o2 sensor but the code still came up then i cleared it and the light came on again a my mechanic said the is no communication between the 02 sensor and computer does anyone have a solution?I could really use some input on this thanks!
Old Aug 2, 2011 | 07:31 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I moved this thread to the Stratus section,
FF
Old Aug 5, 2011 | 08:00 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
It is time to pull out the DVOM and start checking the wires from the controller out to the o2 sensor connector and check power and grounds and ohm test too. You could have either an open wire or bad ECM.
Old Aug 25, 2011 | 11:00 PM
FrankTA2's Avatar
FrankTA2
Default Bad connector
I had the same problem on a 2006 Stratus with the 2.7 V6. After the new sensor was replaced the light came on again. The mechanic tried another sensor, same problem. It turned out to be the connector on the harness side.
