2005 Stratus 2.4 Tensioner
Old Aug 4, 2011 | 09:56 PM
supa16's Avatar
supa16
Default 2005 Stratus 2.4 Tensioner
I cannot get the tensioner pulley to move on a 2005 stratus DOHC 2.4. I have rented a pulley tool (which may be dated) but I cannot find the hole to move the tensioner. I only see the bolt connecting the pulley to the block. Any suggestions would be much appreciated. Thanks
Old Aug 4, 2011 | 11:07 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Which tensioner, the fan belt or the timing belt?
Old Aug 5, 2011 | 02:25 PM
supa16's Avatar
supa16
The serpentine belt. I changed the alternator.
Old Aug 5, 2011 | 07:39 PM
master tech
2.0L/2.4L ENGINE
AIR CONDITIONING COMPRESSOR/GENERATOR BELT
Raise vehicle on hoist.
Remove right front wheel and belt splash shield.
Insert a 3/8” drive breaker bar into the square opening of the belt tensioner pivot bracket.
CAUTION: Avoid excessive force to over compress belt tensioner. This may result in damage to the belt tensioner.
Gently apply a force to rotate belt tensioner clockwise until the belt tensioner bottoms out and the belt can be removed from pulleys.
Remove belt.
Gently release tensioner.
POWER STEERING PUMP BELT
Remove air conditioning compressor/generator belt.
Loosen pivot bolt and locking bolt/nut.
Release tension on belt by moving pump assembly inward towards engine.
Remove belt.
