Starting Problem
Old Oct 16, 2011 | 05:46 PM
jimmyray90's Avatar
jimmyray90
Default Starting Problem
Hey everyone maybe someone can help me i went out of town yesterday the car ran fantastic (seems when problems start to happen lol) well i crunk the car many times yesterday it crank and started up just fine on my way back to town i stopped at a gas station got back in the car and crunk it and the motor will turn but it will not start. Tried jumper cables and not a thing happened still turns but no crank. Fuel pump is operating you can hear it when you turn the ignition key. Ran a OB2 Scan last night when it got off the tow truck it had code p0129-barometric pressure out-of-range low i have no clue what it is and did not have one stored before or any code in the ECU. So what is going on here and what direction do i need to look at i love this car its fantastic
here is what i have
Dodge Stratus SXT 2006
2.4ltr 4-cycl
Old Oct 16, 2011 | 06:37 PM
BillS's Avatar
BillS
don't know if this will help
SYMPTOM
P0129-BAROMETRIC PRESSURE OUT-OF-RANGE LOW
WHEN MONITORED
With the ignition key on. No Cam or Crank signal within 75 ms . Engine speed at less than 250 RPM .
SET CONDITION
The PCM senses the voltage from the MAP sensor to be less than 2.196 volts but above 0.0392 of a volt for 300 milliseconds .One Trip Fault.
POSSIBLE CAUSES
  • IAC signal circuit low
  • IAC signal circuit high
  • Intermittent condition
  • (K6) 5 volt supply circuit shorted to voltage
  • (K6) 5 volt supply circuit shorted to ground
  • (K6) 5 volt supply circuit open
  • MAP sensor internal failure
  • (K1) MAP signal circuit open
  • (K1) MAP signal circuit shorted to ground
  • PCM (K6) 5 volt supply circuit
  • PCM (K1) MAP SIG circuit
Old Oct 16, 2011 | 07:41 PM
master tech's Avatar
master tech
Site Moderator & Tech
Does the engine sound like you have compression?
Old Oct 16, 2011 | 10:06 PM
jimmyray90's Avatar
jimmyray90
How can i tell to see if it is getting compression?
Old Oct 17, 2011 | 05:00 PM
jimmyray90's Avatar
jimmyray90
The Car got took to the shop today and it was a "Dead Battery" didnt know the radio and stuff could run on a low battery still need the regular maintenance the 100K one which includes a Timing Belt/Water pump all new stuff in that area of the motor plus labor he quoted me a price around $550-$600 but usually that is the stuff that needs to be replaced to keep the 2.4 going for awhile right?
Old Oct 17, 2011 | 11:01 PM
master tech
Thats correct. The timing belt may fix your no start problem. Did the shop tell you why the engine wouldn't start?
Old Oct 18, 2011 | 05:09 AM
jimmyray90's Avatar
jimmyray90
Dead Battery they plug 12v right up to it and it fired right up but they said i need to replace the timing belt pretty soon
