need help!!! 2002 Dodge STratus 2.7L V6
Old Nov 24, 2011 | 03:55 PM
adan06's Avatar
adan06
New Member
soo I tried having the fan the entire time until it warms up and it still did the same thing.. it took about 20 minutes to reach normal temperature.and it started to boil again..
Old Nov 29, 2011 | 10:04 AM
Rocket67's Avatar
Rocket67
Check to see if air is getting through the radiator. Don't know if it's applicable but when we used to ride ATV's the radiator fins would get clogged with mud. Maybe something other than mud in your case but it sounds like no air is getting through. Could be bugs...grass....anything. I would definitely check it really good.
Old Jul 16, 2012 | 02:05 PM
Rocket67's Avatar
Rocket67
Wonder how this worked out.
Old Aug 3, 2012 | 11:17 PM
timk225's Avatar
timk225
What is the normal operating temperature on the 2.7? What temperature is the thermostat supposed to open at?
And whatever the stock temperature number is, can it be replaced with one in the 180-195 degree range?
Old Aug 4, 2012 | 08:30 AM
Rocket67's Avatar
Rocket67
Not sure about stock but180 should be ok.
Old Nov 11, 2012 | 01:18 PM
dimochka123's Avatar
dimochka123
The coolant starts to boil in the reservoir and starts to steam outt out from the coolant reservoir overflow.. it starts to do this when it reaches normal temperature.. i have tried changing the cap! and changing the thermostat!!!!i have also tried flushing the coolant and letting the air out from the bleeder on the thermostat housing.!! it still does the same thing dont know waht else to do?? what else could it be??
My engine was overheating a little and the coolant was boiling too. It came out to be that my coolant reservoir is leaking and it doesn't hold the presure needed. I have dodge stratus sxt 2004 2.7L.
Old Nov 14, 2012 | 01:35 PM
tm350's Avatar
tm350
thermostat upside down, possibly
Old Nov 14, 2012 | 01:40 PM
tm350's Avatar
tm350
bleed the coolant i took mine in for mechanic to do it after replacing the bleed housing unit with sensor. i was watching the guy he had pressurized coolant tank too probabbly had tooo pressureisze mine to to get flowing nicely. it runnning greaT NOW MINE 2.7 MAGNUM.
