when I stop it acts like it wants to stall but picks right back up
Old Mar 15, 2012 | 04:18 PM
mikieday's Avatar
mikieday
Default when I stop it acts like it wants to stall but picks right back up
i have a 2004 Stratus 2.4L DOHC 140K runs great. about 6 months ago i had the timing belt/water pump done and all has been fine..i noticed the last few times ive driven it that when i stop at a lite it will act like it wants to stall (not everytime) but then it picks right back up and idles fine
i know currently i have a oil leak from my valve cover , oil level is fine
any ideas
Old Mar 15, 2012 | 10:54 PM
mikieday's Avatar
mikieday
anyone???
Old Mar 18, 2012 | 10:20 AM
mikieday's Avatar
mikieday
is there anything i can check
Old Mar 27, 2012 | 06:56 AM
mikieday's Avatar
mikieday
i changed plugs, wires and valve cover gasket and it seems to run better now. one of the plugs did have oil on it so maybe the o ring leaking caused issue
Old Mar 27, 2012 | 06:25 PM
Strutterstrat's Avatar
Strutterstrat
New Member
Had the same issue with my 02 3.0, I would definatly check for vac leaks and before all else fails your fuel pressure, car managed to act like it had a vac leak before the pump crapped out on me.
Old Mar 27, 2012 | 11:39 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would also clean the throttle body and check the EGR valve too.
Old Mar 28, 2012 | 08:41 PM
HemiMoparGuy1981's Avatar
HemiMoparGuy1981
If the problem is intermittent, you have some good advice to go by, I'd also try some injecotr cleaner, as a partially clogged injector can play havoc...If it is an all the time occurance, I'd take a second look at the timeing belt. My wifes old Stratus 01 2.4L acted like that when I installed the timing belt a tooth or two off (long story, just told it in another thread yesterday if you're that curious) But it ran perfectly fine had good performance and everything, it just ran rough as heck at the light...parked in driveway it was fine, somethign about being in gear and holding the brake...if the brake was let off it'd creep along at a nice smooth idle, but stopped in gear, it missed liked crazy
Old Sep 29, 2012 | 07:34 PM
onlyea's Avatar
onlyea
I have exact same problem. When I stop or put on park rpm drops, but picks right back up. Specially when A/C on. My timing belt changed last year, but problem started like about 6-8 months ago. For this RPM drop issue, I changed the spark plugs, ignition coil, air valve, couple hose, cleaned up throttle body. Put the idle little high, but then I burn so much gas.
I don't know what else to do??? Maybe there is a hose leaking air, but can't find it.
Driving me nuts!!!! I mean it drives fine, but this Rpm drops are killing me.
Old Sep 30, 2012 | 11:51 AM
onlyea's Avatar
onlyea
is this car has MAP Sensor?? Where is it located? 2004 dodge stratus sedan.
Do you guys think It would make difference if I change it?? How about 02 sensor should I change that too???
When where is the Idle control valve located???
Please help
Thanks
