1999 Stratus sputtering missing runs rough
Old May 6, 2012 | 09:23 PM
vsolisv's Avatar
vsolisv
Default 1999 Stratus sputtering missing runs rough
Hey guys i have a 99 Stratus. It is sputtering and runs very rough. It had codes for a coil, replaced ran fine for a few weeks, had a code for a crank sensor, replace ran fine for a day. Sometimes I get lucky and it runs ok. It has no acceleration when applying throttle. Usually when i start it it will miss really bad and die. Checked plugs no signs of misfire and I do not have a misfire code. I replaced the fuel pump roughly 12 months ago with an aftermarket pump, which by the way is very loud. Any suggestions will be greatly appreciated, thanks....
Old May 7, 2012 | 11:57 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Did you find any oil leaking inside the spark plug tubes? That would cause a misfire problem.
Old May 9, 2012 | 12:02 PM
vsolisv's Avatar
vsolisv
I replacd plugs a while back. No misfire codes, just crank sensor code and ignition coil code. Also replaced both of those. Coil is a dodge part, crank sensor is aftermarket.
