cam sensor help please
Old Jun 4, 2012 | 04:50 PM
stratusissues101's Avatar
stratusissues101
Angry cam sensor help please
our car has been giving us issues on and off. when i turn the car on for the first time during the day it has a hard time accelerating past 2000 RPMs...it jerks and bucks and i have to let go of the gass to let the RPMs drop back and accelerate VERY slowly...most days im able to shut the car off wait 2-5 mins and turn it back on and its fine. im getting a code of PO344 and we already had the sensor replaced. i do not have the money for the mechanic to charge me 100.00 everytime he looks at it as he has already charged us for the cam sensor replacement and it didnt correct the issue. PLEASE HELP
Old Jun 4, 2012 | 04:51 PM
stratusissues101
sorry its a 2006 dodge stratus 2.4L engine 4 cyl.
Old Jun 4, 2012 | 04:58 PM
stratusissues101
Old Jun 5, 2012 | 10:08 AM
kavoni6's Avatar
kavoni6
Default Cam Shaft Sensor PO344 error code
If you don't get a response try doing a google search. Always be sure to list your engine size, year, make & model. I know on the 2.5L you have to replace the whole distributor. New distributors will vary in price but mine was $252 at O'Riely Auto Parts. Good luck!
Old Jun 5, 2012 | 10:55 AM
BillS's Avatar
BillS
Where was sensor bought Could be a defective sensor ,have seen several posts about poor quality after market sensors ,might try replacing with one from dodge,check wiring,
Old Jun 5, 2012 | 11:48 AM
stratusissues101
It was done by a terrible mechanic..I don't know where he got the part.
Old Jun 5, 2012 | 11:50 AM
stratusissues101
It's a 2.4l engine...and I've already googled it a couple times but it led me here
Old Jun 11, 2012 | 06:03 PM
ras28's Avatar
ras28
Default Cam shaft position sensor
Hi,
I had a Cam shaft sensor problem.
The problem was with the electric circuit, may be you can get it checked?
Old Jun 12, 2012 | 07:34 AM
stratusissues101
How much did that run you?
Old Jun 12, 2012 | 05:54 PM
ras28's Avatar
ras28
Default Cost of changing the cam shaft position sensor
It cost me $83 total, including the sensor.
The mechanic who repaired it said, 2 of the wires were bad. Which was causing the problem. The sensor was already replaced when I got the car.
After the change, when I was going around 60 MPH I felt slight hesitation in the engine, I think I need to get other wires and timing belt checked!
