2000 Stratus Issues
Old Jul 7, 2012 | 09:30 PM
techgeek17's Avatar
techgeek17
Default 2000 Stratus Issues
my 2000 stratus 2.5 v6 died on the road, got it home thought it was the fuel pump but after testing fuel pump worked fine, after further testing I had voltage to the fuel pump for 1 second when the key was cycled then nothing. Checked fuses and relays all good. On the asd block, I had power to the 30 terminal and 86 terminal with no key on. Then I lost power to the asd block and getting no voltage to fuel pump circuit, the theft light stays on and odometer displays "no bus". I am totally lost. Anyone got any suggestions?
Old Jul 9, 2012 | 01:51 PM
ratsttam's Avatar
ratsttam
Try another key if you have one. Sounds like the ASD is shutting down the fuel pump. Bad key, or a spare with no chip in it will let the car run for 3 seconds before shutting down.
There is also a time-out period where if you keep trying a bad key, it will lock down completely for 15 minutes.
You may need to take it to a dealer if the reader or computer component is failed.
