lifter noise
Old Dec 30, 2012 | 05:26 PM
dodge stratus's Avatar
dodge stratus
Default lifter noise
2001 dodge stratus rt 3.0L has lifter noise how to fix it
Old Dec 30, 2012 | 06:03 PM
go-part's Avatar
go-part
Former Vendor
If it is just a lifter noise
Check to see if there is any sludge in your heads
Check your oil levels
Start there, because you may have to replace your lifters.
Old Dec 31, 2012 | 08:06 AM
bad venge's Avatar
bad venge
Section Moderator
How many miles ?
First thing I'd do is an oil flush , This can clean out sludge in the passage ways/heads/ around the oil pump pickups ect causing low pressure to the heads causing the noise.
Put any of the commercial oil flushes in the crankcase let run per the instructions
Then drain , I like to but in some cheap bulk oil and another filter then let run for 50 miles or so to collect the debris knocked loose. Then do a regular oil change
Old Dec 31, 2012 | 01:19 PM
pearl01stratcpe's Avatar
pearl01stratcpe
Its your hydraulic lash adjusters. I have done this to mine only to have it come back. The link doesnt show your exact engine, but the lash adjusters and locations are most likely identical.
http://www.dsmtalk.com/forums/showthread.php?t=231780
You can do this or run various chemicals through the crankcase, the noise will just come back, but much sooner than if you are to take out the tappets and clean them thoroughly. http://www.4x4wire.com/mitsubishi/te.../lifter_noise/
The procedure for cleaning the lash adjusters after you remove them: http://atlanticz.ca/zclub/techtips/h...r+cleaning.pdf
Marvel Mystery Oil works the same as the diesel, and is easier to obtain with its own container.
