2002 Startus Coupe SXT Issues
Old Jan 2, 2013 | 10:17 PM
Jeremyprz's Avatar
Jeremyprz
Default 2002 Startus Coupe SXT Issues
Alright Ive got two quick questions i need a little help with.
One being this model Stratus is the Mitsubishi build is their any cheap blacked out headlights or way to do it yourself without dropping a load of cash or even a basic replacement being mine and getting pretty rough and the restoration kits suck.
Two when I start my car it tends to have a high pitch squeal for a short time.(worse when its cold) I assume its a slipping belt but don't wanna go sinking money into it and find out its a failing pump or a just my tension pulley. Has annoy one experienced this and what was your results.
Keep in mind I'm only 18 and just started college so a slight budget.
Old Jan 3, 2013 | 02:37 AM
steak59's Avatar
steak59
Restoration kit usually work pretty well for me, they last a year or 2. Maybe you are not using it correctly?
Just spray some soapy water on the belt, if it stop the squealing, you probably just need a belt.
Knowing what size engine you have would help too!
Old Jan 3, 2013 | 11:03 AM
Jeremyprz's Avatar
Jeremyprz
Default Engine
Its a 2.4L V6 SOHC Mitsubishi
Old Jan 4, 2013 | 12:35 PM
pearl01stratcpe's Avatar
pearl01stratcpe
2.4 is a 4cyl, 3.0 is a V6.
