2.5 V6 wont start when it rains
Old Jun 2, 2013 | 08:27 PM
Budman1962's Avatar
Budman1962
Default 2.5 V6 wont start when it rains
I have a 1998 with a 2.5 V6. When it rains it wont run. Runs great when its dry. Even when its really cold it runs fine. I replaced the rotor, distributor cap, plug wires and plugs. Didn't help. I have tried searching online and found it is a common problem for this engine. Lots of people complaining about it but no one has found the answer. Anyone out there have this problem? A mechanic wants to change the distributor and crank position sensor but it's just a shot in the dark. Any help would be great.
Thanks
Old Jun 2, 2013 | 10:08 PM
BillS's Avatar
BillS
have you checked electrical connections for bad sealing or corrosion, dodge had some problems but can't remember what years with the connections on the ECM/PCM being messed up
Old Jun 2, 2013 | 10:17 PM
Budman1962's Avatar
Budman1962
Thanks for the reply. Where is this connection located?
Old Nov 6, 2013 | 02:49 PM
Budman1962's Avatar
Budman1962
Has anybody else had this problem?
Old Nov 7, 2013 | 04:45 PM
NH R/T's Avatar
NH R/T
i had same prob with '01 rt coupe 3.0 wouldnt start in rain and died inside carwash (that sucked)...distrib cap looked like a spider web inside...a million cracks . replaced it and ran perfect
Old Nov 9, 2013 | 12:18 AM
Budman1962's Avatar
Budman1962
I replaced the distributer cap. I will check the ECM/PCM connector. Maybe water is leaking behind the dash
Old Apr 28, 2014 | 11:33 PM
Budman1962's Avatar
Budman1962
Bumpp
