Valve Clatter on 2.5 Engine
Old Jul 31, 2013 | 12:21 PM
oeblio's Avatar
oeblio
Default Valve Clatter on 2.5 Engine
Recently did a head gasket on a 97 Stratus 2.5. Heads were rebuilt. Engine started but much valve clatter so shut down. Rechecked timing belt and is dead on. Suspect lifters are not pumping up. Is there any way to check valve train to see what is up or should I run engine until they pump up.
TIA
Old Aug 7, 2013 | 11:55 AM
oeblio's Avatar
oeblio
Google was my friend. Here is the cure that worked for me.
http://www.4x4wire.com/mitsubishi/te.../lifter_noise/
