P0700 p0720
Old Aug 15, 2013 | 01:43 AM
Hrleybob's Avatar
Hrleybob
Default P0700 p0720
I have 2004 stratus when I come a stop after driving the rpms start going up a little speedo goes up 20mph and the trans bangs like its shifting out n in gear does it every time stop only once at each stop the check eng lite comes on and goes into limp mode codes p0700 n p0720 I'm thinking maybe tcm which is part of PCM any ideas would appreciate some help already replaced output shaft speed sensor
Old Aug 15, 2013 | 10:46 AM
master tech's Avatar
master tech
Site Moderator & Tech
Replace the output sensor and check the two wires going into the connector. The wires
have been a problem too. If the wire or wires have a break, there is a repair kit.
Old Aug 15, 2013 | 11:40 AM
Hrleybob's Avatar
Hrleybob
Thanks master tech already replace sensor and checked wires olm good seem to be fine lock in connector tight no weak spots in exposed wire not sure about inside harness is the wire problem usually found at connector? Also seem to fine at multi pin connector. I did notice that it doesn't hardly do it when ac is not on will do it at every stop as soon as I stop only once per stop when ac is on if that help any
Old Aug 17, 2013 | 12:39 AM
master tech
The wire breaks inside the connector. Just pull on the wires and see if it pulls out of the connector. The A/C shouldn't have anything to do with the output sensor.
Old Aug 17, 2013 | 01:15 PM
Hrleybob's Avatar
Hrleybob
wires at connector are good no broken wires sensor is new just replaced pcm could it be caused by shift solenoid has large multi pin connector that goes into it just cant figure this one out drives and shifts fine just when at a stop rpms go up a little speedo go up to about 20mph trans bumps and then speedo fluctuates around 10mph till starting to accelerate then everything goes normal only at a stop and only bumps one time per stop
Old Aug 18, 2013 | 12:42 PM
master tech
Unless you have an internal problem inside the transmission. I don't believe you have a PCM problem.
Old Aug 19, 2013 | 02:11 PM
Hrleybob's Avatar
Hrleybob
Default found it
ok finally figured it out its crazy forgot techs #1 rule KISS found vacuum leak at pcv valve elbow which was causing idle to be high and surge with ac on causing i guess erratic output shaft speeds making tcm telling pcm that car was going conflicting with speed sensor causing trans to try to shift causing the bump amazing how something so simple could be so confusing lol bought elbow for 10 bucks resulting in normal operation so FYI for anyone having the symptoms i had look for vacuum leak
Old Aug 19, 2013 | 10:46 PM
master tech
Good job! and thanks for the update.
Old Dec 27, 2019 | 04:07 PM
Mark83's Avatar
Mark83
Smile That PCV leak tip worked for me also!
Just before I started getting serious about diagnosing the 2004 Stratus in "Limp" mode and thinking I had a huge transmission issue to deal with, I checked Hrleybob's tip to check the PCV valve elbow on the top of the engine. It looked fine, but when I took it off to check for cracks the entire elbow disintegrated! I replaced it with a 3 inch reinforced hose and clamps, disconnected the battery for 30 minutes instead of the usual 5 minutes to clear the code/"Limp" mode, then reconnected, re-started and let the engine "Re-Learn". Worked like a champ! Thank you Hrleybob! Happy Holidays!
