01 r/t 3.0
Old Nov 2, 2013 | 01:15 PM
Jericho86's Avatar
Jericho86
Default 01 r/t 3.0
Hey everyone,
I have a 01 R/T 3.0 with a few issues.
1) it idles low( used to be only when I turned on heat/ac now it's constant)
2) it dies from low idle at times and sometimes, it even losses power completely! To where I cannot start it unless I wait a few minutes. Im don't know if this is a short caused by the remote starts toggle switch recently being broken. Possible?
3) engine check light goes on and off and after losing power it resets it's self before I can pull the codes.
If you could help send me in the right direction that would be greatly appreciated thanks for reading
Old Nov 2, 2013 | 02:24 PM
BillS's Avatar
BillS
if there are any codes they should still be there, could possibly be toggle switch depending on how it was wired ,have you checked for any vacuum leaks I would first try cleaning the throttle body up with some throttle body cleaner( or carburetor spray if they still make it ) then try cleaning idle air control valve you can find a few hints on how to clean it by using search link above for Stratus idle control i'm not to familiar with coupe
Old Nov 3, 2013 | 04:04 PM
Jericho86's Avatar
Jericho86
I pulled the codes and they are 431/421. I cleared the codes and it appears to be fine..
