How do i know if Auto Tensioner is Bad
Old 06-28-2014, 12:35 PM
mylastcar's Avatar
mylastcar
mylastcar is offline
Default How do i know if Auto Tensioner is Bad
manual say's to check for amount of travel in Auto Tensioner and if more than .040 thousandths, it's bad. any one have a easier way to check it? Manual says to -
(apply 22-44 lb force to pushrod by pressing it against a metal object and measure the movement of the push-rod. if outside the standard value , replace it. ) standard value being .040
Old 07-07-2014, 11:17 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Anytime the timing cover comes off to get to either the water pump or replacing the timing belt. Replace the tensioner.
Quick Reply: How do i know if Auto Tensioner is Bad
