No buss code
Old Jul 17, 2015 | 04:21 AM
atcfreak250's Avatar
atcfreak250
New Member
Default No buss code
new here guys.
haveing a big issue with my 99 dodge stratus 2.4 se.
while back i notice my gauge cluster would just die.no fuel,speed,temp, or tac would work.only the brake and oil lights would work.i would have no wipers or defroster. everything else would work find.car would start and run find.when you turn the key on and let if sit it will read No Buss and the airbag light would stay on untill you start the car then after a few sec it will go out.
if you unhook the battery and reconnect it everything will come back on like it should.but i say a hour or less it will happen again.
iv check everything.fuses,wiring.cluster.nothing seems to broke or fried.
im hoping someone on this site could help me out.
thanks for any help.this has me lost
Old Jul 18, 2015 | 10:44 AM
atcfreak250
New Member
nobody can help me out?
Old Jul 18, 2015 | 06:01 PM
BillS's Avatar
BillS
have you done anything to car recently before problem started, no buss is a communication problem could be loose connection ,corrosion in fuse box where main buss is , not sure if your car has box under hood ,bad module ,might need reprogramming there was a bulletin issued by dodge not sure of years it covered
Old Jul 18, 2015 | 10:32 PM
atcfreak250
New Member
checked all that.
today i found out that the tcm and fuel pump relay are getting hot when the car is running.
could you get me a link on that bulletin?
Old Jul 19, 2015 | 10:17 AM
BillS's Avatar
BillS
have you checked to see if there's any codes stored(autozone or advance check for free) could help diagnose problem . when you unhooked battery how long did you leave unhooked ? I would try unhooking(scan for codes before doing this) 10-30 minutes then start car let idle for at least 5 minutes see if modules are able to establish communication again. I couldn't find that bulletin got rid of my stratus 3+ years ago don't have access to that website anymore , found this might help some http://jsautosource.com/my-projects/...art-no-gauges/ also try a general search engine for "stratus no buss" might help this forum not very active anymore
Old Jul 25, 2015 | 07:59 AM
atcfreak250
New Member
iv tryed to get codes,just saids there are no codes
Old Aug 11, 2015 | 10:35 PM
atcfreak250
New Member
found the problem, it was the bcm bad
Old Sep 13, 2019 | 12:58 PM
frustratred's Avatar
frustratred
What does that mean ?
