2001 R/T Heater
Old Dec 6, 2005 | 04:03 AM
manikinxvx's Avatar
manikinxvx
Default 2001 R/T Heater
I apologize if this topic has already been addressed and I missed it.
I just bought my R/T last month and I'm having issues with how long it takes for the heater to warm the passenger compartment... especially with the frigid temps we've had in the midwest for the past few days. Although, the issue isn't completely simple. Obviously it'll take time to warm up, but it seems to alternate between warm and cool air... seemingly in a cyclical pattern.
Undoubtedly, I will be calling the dealer on this matter, but cosidering a couple other issues for which they haven't been able to pinpoint a cause, I'd like to present them with ideas (other than the thermostat) if anyone knows of anything.
Old Dec 6, 2005 | 02:04 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: 2001 R/T Heater
i find that to be VERY odd, as my AC and heater seem to get working VERY quickly.
Old Dec 6, 2005 | 03:26 PM
manikinxvx's Avatar
manikinxvx
The dealer says it's probably just a matter of a slow-response thermostat. Additionally, they said that since car is originally from Florida, the thermostat just simply may not be able to 'cope' with the needs of a midwest winter.
Old Dec 6, 2005 | 04:42 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
they put the same thermostat in every car...unless it was changed. i have a lower degree t-stat in my RT, and the damn heater would still cook you out, and in a hurry.
Old Dec 6, 2005 | 04:49 PM
Stratusse2001's Avatar
Stratusse2001
Does the cold air start to come when not acceleration like at stop sign or traffic light. I had a problem similar with my 01 Sedan Se where it would stop giving heat when off the gas. They found an air pocket in my radiator. Maybe this will help.
Old Dec 6, 2005 | 10:15 PM
manikinxvx's Avatar
manikinxvx
Yes, the cool air does seem to be more prominent at lower RPM's, I'll mention this to the dealer. Thanks.
Old Dec 9, 2005 | 08:46 PM
redgtiguy's Avatar
redgtiguy
im having the same issue on my stratus. did you find out from the dealer what the fix was on yours?
Old Dec 14, 2005 | 08:05 PM
manikinxvx's Avatar
manikinxvx
It was a combination of an air pocket and low coolant... although the coolant level was prob'ly lower after bleeding out the air pocket.
Old Dec 18, 2005 | 05:26 AM
nate_0022's Avatar
nate_0022
yeah i just had that same problem with my R/T a couple days ago just put some coolant in the radiator ropped of the resirvouir and everything is fine i didnt do the 50/50 though just put straight coolant in and now my car is pretty much warm when i start it so maybe you should check the collant level
