Turbo Stratus R/T
Old Dec 28, 2005 | 01:04 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: turbo manifold
pita is "pain in the ***"....
and i wouldnt call twin turbo overkill...this isnt the fast and the furious..im sure that he doesnt have two 100 trim turbos...
Old Dec 28, 2005 | 01:20 PM
X_Spearmint's Avatar
X_Spearmint
ORIGINAL: BadStratRT
lol. I'm planning on running between 5 and 7 psi through em. Nothing crazy. It's a pair of t3's not a pair of t78's. No wonder I was sitting there going who the f*** is pita? I have a feeling they might make a turbo manifold for the 2000+ V6 Eclipse, wouldn't that fit? I understand why the vr4 ones wouldn't, but the V6 eclipse is the same setup as the r/t.
Old Dec 28, 2005 | 01:33 PM
highrevr/tflea's Avatar
highrevr/tflea
custom manifolds should run you no more than 220 apiece....
Old Dec 28, 2005 | 01:46 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
yes..manifolds for the 3g eclipse will fit, and while youre spending money, find yourself the intake plenum off of a 3g eclipse GTS. I believe that the 6g74 vehicles had the "higher flow" manifold as well...like the SUVs with the 3.8L, i believe......you could get them before for around 100 bucks. they are direct bolt up manifolds, but they produce an advertised 10hp jump over the GT manifold, which is what our engine has.
Old Dec 28, 2005 | 07:43 PM
X_Spearmint
I've been on the mitsubishi forums and apparently they just run the stock manifold most of the time. probably because the performance ones made by rpw are sooooooo expensive($910).
Old Dec 28, 2005 | 07:47 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i understand that, but the 6g74 intake swap is very popular, and its much cheaper than a whole new performance intake. i could have gotten one for 80 bucks WAY back...but i didnt...im not saying that the stock intake isnt good enough, but the GTS intake flows better, enough so to free up stock HP.
Old Dec 28, 2005 | 08:05 PM
X_Spearmint
what about the exhaust manifolds?
Old Dec 29, 2005 | 01:31 AM
X_Spearmint
well I think some of you may enjoy this immensely
http://tearstone.com/shop/index.php?...pshop&Itemid=2
Yes, that is a turbo kit that will fit a V6 Stratus.
Also is the 6G74 the motor in the 97 3.5L Diamante?
Old Dec 29, 2005 | 01:38 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i have seen the tearstone kit on an eclipse...as for the diamante, i do believe that it is the 6g74
Old Dec 30, 2005 | 01:31 AM
X_Spearmint
Well my T3's arrived today. This is gonna be sweet.
