Turbo Stratus R/T
Old Dec 30, 2005 | 02:02 PM
  #21
X_Spearmint's Avatar
X_Spearmint
Default RE: turbo Stratus
Sorry for the double post.
I wanted to get your thoughts on dropping VR4 pistons, rods, and rings on the stratus. According to the mistubishi guys they'll fit. Good or bad idea?
Old Dec 30, 2005 | 03:19 PM
  #22
rdross22's Avatar
rdross22
Man thats Awsome. I went to the site and read all the specs about it. are you going to put it in yourself or a pro? My buddy tried putting that one on his eclipse but half way through got stuck like chuck. Do you have all the other mods to intall it?
Old Dec 30, 2005 | 08:53 PM
  #23
X_Spearmint
I actually won't be getting the kit, because I already have a couple of Garrett T3's. Why pay that much for a kit that includes a turbo you don't need? That and I'm going twin turbo. If I wanted to run an insane amount of boost I'd go single, but as I'm not....
Old Jan 8, 2006 | 08:18 PM
  #24
X_Spearmint
Well I think I've decided on how I'm going to do this. I'm thinking Dual Turbo setup. I'm sure this is going to get quite expensive. I think I want to use water-air chargecoolers instead of the typical air-air intercoolers as it is a dual setup. it'll be interesting getting 2 intake manifolds made for it. I'm thinking of a functional hood scoop to ensure that both turbos get the same amount of air as well. Just wanted to put that out there and get your thoughts on it.
Old Jan 8, 2006 | 11:51 PM
  #25
highrevr/tflea's Avatar
highrevr/tflea
Hood scoop isnt really goin to help your ambient air intake as much on the compressor wheel ...your best bet is to get an intake piece on the turbo and let your intercooler do the work its s'posed to. Good luck on the turbocharging process...being that its custom like mine its goin to be fun! LOL
[IMG]local://upfiles/15699/F968CC3A9D034A8CA761CA08E200BC1F.jpg[/IMG]
[IMG]local://upfiles/15699/53EE16C9C3C246E3A3240841AA387A6E.jpg[/IMG]
Old Jan 9, 2006 | 01:17 AM
  #26
X_Spearmint
I should've elaborated on the hood scoop, it's not really to increase ambient air flow it's going to be used more to help maintain a balanced airflow through each turbo, that way both get the same amount. Remember, I'm going for dual turbo, not twin. And I'm looking at using a charge cooler for the same reason as the hood scoop, to maintain balance, so instead of being air cooled I'm looking at water cooled, much easier to ensure a balanced cooling system.
Old Jan 9, 2006 | 05:47 PM
  #27
highrevr/tflea
your goin for inline? WOW...The only other inline Ive ever seen is on a GSR integra and that thing was smokin fast...it was trailored in @ a restaraunt here ran high 8s low 9s...were you doin internal upgrades? WOW thats just awesome if you can do that to a strat that would be one hell of an accomplishment. Were you mimicing any certain car w/ this same setup or just thought of doin this yourself?
Old Jan 9, 2006 | 05:50 PM
  #28
X_Spearmint
I've seen it on a V8 Turbonetics Supra and a couple V6's. And I'm running them Parrellel not inline. One turbo for cylinders 1-3-5 and one for 2-4-6.
Old Jan 9, 2006 | 05:54 PM
  #29
highrevr/tflea
wow I bet that will still kick out some HPs...I hope you get it done by spring so I can start seeing it out in summer events...Ill be autocrossing in flint this spring when I get my car done...
Old Jan 9, 2006 | 06:01 PM
  #30
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
the turbonetics supra that i saw was a 2jz...what v8 was the car that you saw using?
highrever, what is that turbo setup that you showed, on?
