car making a noise
Old Mar 9, 2006 | 04:48 AM
highline95jl's Avatar
highline95jl
Default RE: car making a noise
Most Chrylers Ive been around have always had a knock on cold mornings, the car warms up, knocking goes away.
Old Mar 9, 2006 | 03:57 PM
Jrseykid686's Avatar
Jrseykid686
its not just a cold engine knock... you can hear it from inside the house with the car in the driveway... its truly embaressing driving a car like mine when it sounds like the engine is about to blow up.
Old Mar 9, 2006 | 05:18 PM
highline95jl
Could be a lifter as pat said. Hows your alternator? Ive discovered a bad alternator makes alot of noise and if your running alot of audio systems theres a good chance your killing it. Check your lifter and also hows your oil, if you have too much or not enough its gonna make the thing sound and run like *** too.
Old Mar 9, 2006 | 06:06 PM
Jrseykid686
how do i check the lifter?? also it might be my alternator, it had a system in it before i bought it... the wires were there, and i also have one now... how do i check that and do you know if its covered under the powertrain?
Old Mar 9, 2006 | 07:41 PM
highline95jl
Alternator should be under warrenty because its part of regular maintenance, if youve had systems in that thing for the life of the car I say your alternator might be overdue but I dont think thats the cause of your noise.
Some things to check like possibly thick/dirty oil might not be getting to your lifters and that could cause the knocking. Might even be a rocker arm, or even possibly a **** oil pump not giving you any pressure. Plugged oil port, so on and so fourth.
All this should be covered under your warrenty.
Jrseykid686
i didnt think so either, but good to know its under warrenty....
