2001 Stratus Check engine
RE: 2001 Stratus Check engine
It's located somewhere on your exhaust pipe before your catalytic converter. pull it out and see if you have any obvious defects. if it's shorted to the tailpipe, or the wiring has chaffed against something, that could give you the signal. replace the sensor or fix the wiring. After the fix you need to get the check engine light turned off by a maintenance guy, unless you have a reset unit.
Let me know how it goes
