CAM position sensor
Old Jun 17, 2004 | 07:35 PM
pablito's Avatar
pablito
Default CAM position sensor
Hi guys!
Can anyone tell me where the cam position sensor is on my 97 dodge stratus 2.4. dohc? A picture would be great! Thanks!
Jesus still saves!
Old Jun 21, 2004 | 07:20 PM
lvd2340's Avatar
lvd2340
Default RE: CAM position sensor
The camshaft position sensor is mounted to the rear of the cylinder head.
[IMG]local://upfiles/4800/Om320857221.gif[/IMG]
Old May 17, 2011 | 01:20 PM
StratusFear96's Avatar
StratusFear96
I didn't want to start a new thread, could someone please post a picture or diagram of where the cam sensor is? I have a 96 2.4 v6 stratus and I may have a problem that requires replacement of the cam sensor. Thanks in advance
Old May 29, 2011 | 02:29 PM
myt69mopar's Avatar
myt69mopar
I have a 98 Stratus V6 and the camshaft sensor is located in the distributor. I'm pretty sure all V6's are in the distributor.
Old May 30, 2011 | 12:19 PM
StratusFear96
thanks for the reply! I changed the cam sensor but I am still having the hesitation @ 40-50-60mph. Currently, it's only throwing a cylinder 5 misfire code. Perhaps, that is the hesitation I've been experiencing....any suggestions on a resolution?
Old May 30, 2011 | 02:47 PM
master tech's Avatar
master tech
Site Moderator & Tech
You need to remove the plenum and remove the number 5 spark plug. You may found oil in the spark plug tube. The oil leaking into the spark plug hole could be causing the misfire.
