Rear Speaker Problems – Amplifier
Old Jul 10, 2006 | 07:49 PM
julfaj's Avatar
julfaj
Default Rear Speaker Problems – Amplifier
I just bought a 2001 Dodge Stratus R/T and I am fixing what the MORON of an owner did to the poor car. I am having problems getting the rear speakers working. The front speakers and even the tweeter work but not the rear, I am unsure of the Center speaker as well. I am getting voltage from the POSITIVE wire but when I use the negative I get nothing. Any help would be greatly appreciated.
P.S.- Does anyone know where the Infinity Amplifier is located in the Coupe Models
Thanks
Old Jul 10, 2006 | 08:34 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: Rear Speaker Problems – Amplifier
its under the passenger seat. my amp died after about two years...however, when i put in my subs, i had to tap into the pre-amp rear speaker wires...and use an rca adapter
Old Jul 11, 2006 | 12:42 PM
julfaj's Avatar
julfaj
Thank you, I'll check on this today after work.
Another question I had was The clock in the middle in the dashboard does not work. The light works and it's nice and bright but it doesn't display anything. Is there an easy way to remove the top part of the dashboard?
Old Jul 11, 2006 | 03:47 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
do you mean the compass? i dont have a clock...
Old Jul 11, 2006 | 04:14 PM
julfaj's Avatar
julfaj
I'm guessing, it's right in front of the Center Speaker. It's never worked so I'm not sure what it does. I keep pressing the ON button but it wont turn on. All I get is the background light but no display.
Old Jul 13, 2006 | 01:27 PM
julfaj's Avatar
julfaj
If I can hear audio when I am using the Radio but then when I try to play a CD there is no Audio comming from the speakers, do you think there's something wrong with the AMP?????
Old Jul 13, 2006 | 03:32 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
that sounds like a head unit issue, if it works in radio mode.
Old Jul 13, 2006 | 03:42 PM
julfaj's Avatar
julfaj
Thats what I figured but I tested the unit in my other car and it works great. I can't figure out what in the world is wrong. Would the Infinity Amp cause this issue?
Old Jul 14, 2006 | 04:08 PM
srogers's Avatar
srogers
I work for Infinities parent comapany where all warranty issues goto.
What I am wondering is what head unit do you have?
The cd portion of the radio can be bad.
We get a lot of failures for the RB4 radio here. What happens is the motor that actualy spins the cd dies. So you get sound from radio and nothing from the cd. We also get a lot of returns, cause people try to put more then 1 cd into the player. I opened one up once ande found 6 cds jammed inside the cd player. The problem they reported, was: will not accept cd. Hmm wonder why.
Have you tried to hook up a diffrent head unit to this vechicle? I would guess it be the head unit, but the amp can cause problems, but when you get sound from the radio portion and nothing from the cd portion, more then likly head unit problem.
Let me know a little more infor and I MIGHT be able to help ya out.
Old Jul 18, 2006 | 11:42 PM
nathan24's Avatar
nathan24
The negitive wire might be split somewere
