Engine runs after key is out
Old Jul 22, 2006 | 02:44 PM
jlprice1255's Avatar
jlprice1255
Default Engine runs after key is out
My 2000 Stratus contiunes to run after the key is taken out. Dodge has had the car for over a week and can't tell me what's up. They say that the Starter is fine and all relays and fuses good. Ignition is also alright. What to do anyone?
Old Jul 22, 2006 | 03:05 PM
dodgerules86's Avatar
dodgerules86
Default RE: Engine runs after key is out
ORIGINAL: jlprice1255
What do you have to do to turn the car off?
Old Jul 22, 2006 | 03:16 PM
inkedokie's Avatar
inkedokie
My 2000 alero did the same thing it turn off however but once it was on all the way u could pull it out.
Never had no major problems did it for couple years never found out y.
Old Jul 23, 2006 | 02:19 PM
jlprice1255
I turn the key normal, it just keep running for a while everything is still on in the car until the engine dies.
Old Jul 23, 2006 | 02:21 PM
jlprice1255
So I should have nothing to worry about as far as replacing the battery before it's time? Did it stop doing it on it's own?
Old Jul 23, 2006 | 05:00 PM
inkedokie's Avatar
inkedokie
no i could just pull the key out from the on position i guess i read your deal wrong <> After u turn the key to the off position it is still on if this is so I have no clue .
Old Jul 23, 2006 | 07:08 PM
leftfun's Avatar
leftfun
the only way to solve the problem is checking ur computer, maybe something wrong with the little plug in it.
however, the dealer cant find out the problem that's not a good sign.
wut a dodge! i have heard many ppl complain about the dodge's customer services is not that nice.
Old Jul 28, 2006 | 07:02 PM
jlprice1255
About the computer, if it was to get replaced would that just reset the codes? Or is that the engine needs the computer before start up? Could it also be that when they replaced my timming belt that maybe some of the teeth was damaged and it'd throwing the car off?
Old Jul 29, 2006 | 12:42 PM
tomthedog's Avatar
tomthedog
sounds like the key switch is faulty. the switch cuts power to the ignition, fuel pump, and computer. somehow the electric power to your motor is not cut when you turn the key to off. may be bad contacts in the switch or some relay (contacts stuck together). norm this prevents things from working, don't see why it can't happen the other way round. the dealer sounds like they just checked for "open" circuts, i think they need to check for ones that are "closed" when they need to be "open". let us know the deal, good luck.
Old Feb 18, 2013 | 06:09 PM
danniel's Avatar
danniel
i got a 2000 stratus that runs with key out ...its getting power from somewhere keeping it running... i disconnected ignition switch still running..i need help please!!!!
