Unplugging Resistor Wire Harness
Old Sep 25, 2006 | 12:26 PM
mbehum's Avatar
mbehum
Default Unplugging Resistor Wire Harness
Stupid question, guys, but can you give me advice on unplugging the fan blower resistor wire harness??? It didn't seem to budge much when I tried pulling it out, and even after I pressed on the center of it and tried pulling it out I couldn't get it. Is there a release I'm not seeing? Stupid question, I know, but this is what's standing in between me, and fan settings 1-3 being operational once again. Chintzy resistors.
Matt
Old Sep 26, 2006 | 10:16 PM
tacoboy's Avatar
tacoboy
Default RE: Unplugging Resistor Wire Harness
There should be a release tab there to push then the connector comes out. Perhaps it's on the side that is facing away from you, I can't remember. Maybe push the connector all the way in first then push the tab hard and pull - maybe since you've been pulling on it there is pressure on the release tab that won't let it release.
I've done this job myself a couple of times so I know where you're coming from! Those resistors are junk! I have actually spliced them with butt-end connectors after they've failed to extend the life of the resistor block and not give Dodge any more of my money!
taco
