Need help with check engine codes
Old Oct 17, 2006 | 07:23 PM
c0dex's Avatar
c0dex
Default Need help with check engine codes
I have a 2003 Stratus SXT Sedan that just started to show the check engine light. I have driven it 2 times since i got it back from the dealership to have the Solenoid Pack in the transmission replaced. The car has driven perfectly the 2 times i have driven it since i got it back and this is the first time the check engine light has ever come on. My question is what am i doing wrong beacuse i can't get the check engine codes to display? I have tried doing the keydance of turning it from the off position to the on position 3 times but i cant get the flashing display to get the codes. Maybe i am doing it too fast or too slow? Any advice is greatly appreciated.
Old Oct 19, 2006 | 09:58 AM
tacoboy's Avatar
tacoboy
Default RE: Need help with check engine codes
Make sure you are turning it off then full on (dash lights on but don't start). You can do it pretty slowly - it's not the kind of thing that has a tight timing window. It takes a few seconds for the codes to flash when you turn it on for the last time.
taco
