2000 stratus 2.4l question
Old Feb 23, 2007 | 03:01 AM
H.P.fanatic13's Avatar
H.P.fanatic13
Default 2000 stratus 2.4l question
Hi I'm new here just got my stratus. Was just wondering if the 2000 pt cruiser 2.4l is the same as the 2000 stratus 2.4l engine? I wanting to know cause if I buy the headers for a 00 pt cruiser if it'll fit on my 00 stratus 2.4l? thanks for the help. and hope to hear from you guys soon.
Old Feb 24, 2007 | 02:06 AM
B_52's Avatar
B_52
Default RE: 2000 stratus 2.4l question
If your running the Stratus Sedan, I believe the 2.4l is the Chrysler made EDZ, and the same engine used in the PT..
http://en.wikipedia.org/wiki/List_of_Chrysler_engines
http://en.wikipedia.org/wiki/List_of_Mitsubishi_engines
The Coupe used the Mitsubishi 4G64, and should be significantly different.
Best let someone here that has more knowledge of the Chrysler line speak up... Mine is limited on the comparisons, sorry
Vince
Old Feb 24, 2007 | 10:51 PM
H.P.fanatic13
actually that helps alot. but if anyone knows for sure. That obviously would be best. I think they are though
Old Feb 24, 2007 | 11:14 PM
superstrat97's Avatar
superstrat97
the 2.4 is the same across the line(however the turbo motors are slightly revised from the n/a motors) so the manifold should bolt up to the motor, but i couldn't tell you weather or not the down pipe will bolt up or if there will be clearance issues.
Old Feb 25, 2007 | 10:09 PM
H.P.fanatic13
sweet thanks that is what I was really looking for.
