Dodge Viper The almighty Dodge Viper. No matter the year, since it's arrival, the Dodge Viper has made even the most refined car enthusiasts drool. This sports car has it all from a sexy look to pavement shredding power.
Door locks
Old May 8, 2006 | 07:04 PM
jorge332655's Avatar
jorge332655
Default Door locks
Stupid question just being proactive though. If my key fob stops working how can i open the doors? Is there a release in the trunk or something?
Old May 8, 2006 | 09:54 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Door locks
JViper should be able to help, he has a SRT. I do not have that issue with my RT10, no windows
Old May 9, 2006 | 07:50 PM
Jviper's Avatar
Jviper
You can replace the batteries.
Old May 9, 2006 | 09:22 PM
CarGuyOhio's Avatar
CarGuyOhio
This may be helpful, I found this for you on another site......
Sounds like you're in "sleep mode", which means you won't be able to use the fobs until you get into the car using the below procedures:
Use the key to unlock the door in the hidden location below the side bulge. (Don't worry, it's going to feel like you'll break the key if you turn any harder... just turn!)
Then.... use the key to turn the ignition, and that'll get it out of sleep mode.
Fobs will work as usual after that.
Re: Locked out, Help
#481630 - 12/17/04 11:29 AM Edit Reply Quote Quick Reply
Try pushing in hard on the door near the handle when turning the key in the scallop. It's a little tricky at first, and always requires that you push in the door, but it is mechanical and it will work.
#481661 - 12/17/04 01:42 PM Edit Reply Quote Quick Reply
Thanks for the help. Pushing on the door as I turned the key was the trick. I was afraid of breaking off the key when I tried it before. I did have to jump the battery to get it started, thanks again
Old May 9, 2006 | 10:06 PM
CarGuyOhio's Avatar
CarGuyOhio
Oh yea, welcome, always nice to have another Viper owner here. Post some pics in the gallery so I can nominate you for Ride of the Month sometime.
Old May 10, 2006 | 07:39 PM
jorge332655
Thanks for the info.. I wasnt actually locked out yet but the though did cross my mind. Im always around water I figure at some point im going to jump in with my keys or something stupid like that. Jonny walker will do that to you. Thanks again for all your help. I will post some pics as soon as i take some good ones.
